As my bike is nowhere near my current location, I need someone with the standard exhaust at hand to measure some diameters and distances. I need these while fabricating my one-off all stainless exhaust. The measurements I need are described in the picture below.
A = The length of the collar on a standard XBR exhaust
B = The length of the tube that goes in the exhaust port
C = The outer diameter of the tube that goes in the exhaust port
D = The outer diameter of the collar on a standard XBR exhaust
E = The distance between the screw holes on the standard XBR exhaust flange (measured between the centers of the holes)
F = The inner diameter of the pipe flange center hole
Hopefully someone has these parts at hand since I'm in a bit of a hurry with these. Measurements in mm's (± 0,05mm), please.
