Author Topic: SLR 650 fork oil - what grade??  (Read 538 times)
Frog
« on: August 21, 2011, 12:39:44 PM »
Hi
I have and SLR  and just drained the forks which much needed fresh oil.
The manual tells me how much and gives an oil level BUT it gives just says 'fork fluid'.  ???
I am heavy and found the forks a little spongy so may increase pre-load a little but what grade do people recommend?
Frog
Dick Scratcher
Re: SLR 650 fork oil - what grade??
« Reply #1 on: August 21, 2011, 08:41:14 PM »
'Fork fluid' ?........fork oil is usually 5w the same as auto transmission oil but there are 'stiffer' grades available, suggest 10w and see how you get on.
Frog
« Reply #2 on: August 22, 2011, 06:27:11 PM »
Thanks - yes the manual is unhelpful. :-\
I'll try some 10w and tune from there.
Frog
