Author Topic: Replacement seat and handle bars  (Read 725 times)
guest1350
« on: August 18, 2011, 12:29:57 PM »
My bike was converted to a cafe racer style with clipon's and a single seat.
I fancy it a little more "sit up" like in this picture of a SRX600
Any idea were to get hold of a set of bars like on that bike and a replacement "Normal" seat?
Thanks
Tim
Re: Replacement seat and handle bars
« Reply #3 on: August 21, 2011, 09:30:05 PM »
i'll swop you a 'normal' seat for your single seat..... is your existing seat using a 'normal' base with the lock?.... if so it would just be a case of changing them over.
guest1350
« Reply #4 on: August 22, 2011, 08:10:39 AM »
Hi, yes the base is a normal one but there is no lock. The person who fitted it had to cut a hole in the mud guard to access the lock bar from underneath.
You could could do the same but I really would not recommend it. Perhaps you could make an access lever that did not require such drastic measures.
Here is a picture of it from my previous owner
« Reply #5 on: August 23, 2011, 06:58:54 AM »
not a problem, i'll email you a pic of the spare seat i have here. i'll modify the lock so that any key will open it. i would have had to do that anyway if i was going to use it.
