Author Topic: Wiring problems for Yamaha SR125  (Read 476 times)
bikerboi37
« on: July 12, 2011, 10:36:00 AM »
HI I need help.  I have just had to cange the wiring loom for my 1985 Yamaha SR125SE to a loom from a 1991 bike i think and i am still not get in and electical activity i know the loom has a sidestand relay and plug for the switch but the 1985 version does not have a sidestabd switch and i am thinking this is the problem how if it is how can i by pass this section of wiring as i take it i will have to do thinks to both the relay and also the switch.   Can any one help me.
Nigel
pigafetta
Re: Wiring problems for Yamaha SR125
« Reply #1 on: July 12, 2011, 12:11:29 PM »
I've not owned an SR125 but there should be 2 wires that lead to the sidestand switch. If you join the 2 wires or bridge the pins in the connector with a bit of wire, the relay will think the stand is up and you'll be good to go. You shouldn't need to remove the relay unless it's faulty.
Dave B
