Author Topic: Srx valve clearance  (Read 446 times)
guest1166
Srx valve clearance
« on: May 13, 2011, 05:34:11 PM »
I am about to attempt to adjust the tappets on my 400 and have a service book so have got the clearance figures  as there is bog all other information I just want to know if there is anything in the "procedure" that I should be warned about first. I'm a fairly experienced "tinkerer" but more used to mucking around with mouldy old Land Rovers than bikes and just want to know if there's anything out of the ordinary involved.
Re: Srx valve clearance
« Reply #1 on: May 13, 2011, 06:37:18 PM »
Nothing out of the ordinary. With a cold engine:
  • Remove the two inspection covers on the generator cover
  • Remove the spark plug
  • Remove valve inspection covers
  • Rotate the engine anti-clockwise using the flywheel retaining nut untill you can see the 'T' mark through the smaller inspection window.
  • Check the valves to see if on compression or exhaust stroke
  • If on exhaust stroke rotate engine 360 degrees
  • Check clearance and then refit covers etc.
The screw adjustment screw has a square end which can make it fiddly to turn
