Author Topic: SRX6 Question  (Read 679 times)
guest1120
SRX6 Question
« on: April 18, 2011, 08:18:25 PM »
I have had a SRX6 project bike for a while, I intended to restore it and I've sourced a few missing parts from ebay, as you do, but I've also made zero progress, as you do, (unless of course your name is Ian).
My bike is about 99% complete and I've almost sold it a few times but something keeps holding me back............  ::)
Anyway..... enough blathering! has anyone fitted a set of wire spoked wheels to the SRX6? If so, then what hubs did you use? Ideally, I would like to use the original twin discs on the front and single disc on the rear, so what is needed, what mods were required and how do I go about doing it? I want to keep standard forks and twins shock swingarm and the wheels will remain 18" too.
Re: SRX6 Question
« Reply #1 on: April 19, 2011, 07:29:34 AM »
It can be done using the original brakes.
But the brake calipers get quite close to the spokes.
The pictures are from a german bike seen at the monoconnection rally. The front looks to me like an XS650 hub with adaptors made up for the brake discs.
I dont know what the rear is but I beleive XT600 hubs have been used.
I took a different approach with a single 320mm disc on the front
« Last Edit: April 19, 2011, 07:32:49 AM by Steve H »
guest1120
Re: SRX6 Question
« Reply #2 on: April 21, 2011, 09:47:17 AM »
Thanks for this, great pictures too!!!
It's given me a good starting point for a bit of homework and investigation......  ;)
Re: SRX6 Question
« Reply #3 on: April 23, 2011, 09:25:39 PM »
Unusual swinging arm too!
