So, as my bike is slowly starting to look like a bike, I'm at the point where I need to start thinking about electronics. As many of you know, my build is about minimalisation and the same theme goes with the electronics (well.. sorta anyways..). I've planned my electronics as follows:
- No electric start
- LED turn signals
- LED rear- / brake- / registryplatelight
- LED parking light
- LED instrumenpanel lights
- HID / Xenon Lo/Hi-beam
- Only one of the original horns will be used (
beep)
As LED lights have a far less wattage compared to filament bulbs of the same intensity, the size of the battery needed will be minimal. I have cocidered running this bike with a capacitor, but feel like "charging" the caps before each startup would be too much of a PITA for a daily driven bike.
So I need a small battery, the exact rating is not yet clear but I know it's definately way below the standard one. I've looked into LiFePO4-batteries (also known as A123 batteries) since it's possible to make your own battery using several cells (
http://www.youtube.com/watch?v=UTDctiyUa9E <-- a video of creating one of these suckers). However, there seems to be some tampering required to make this battery work with the stock charging system, a quote from ffjmoore@dotheton.com:
I have been doing a ton of research on those batteries. They will run your bike fine. The problem with them is the charging system on your bike was not built for that style of battery. I have not tested it out yet but from what i have learned the battery will last longer if charged within its operating limits and balance the charge between batteries. To do this you just need a circuit board that limits the max and min voltage as well as balances the charge to the batteries. Its called a BMS.
So, anyone have any experience on making or using one of these LiFePO4 batteries? Also If anyone has any other tiny battery options, feel free to share!
