Author Topic: SRX 600 Reg/Rec keeps blowing????  (Read 854 times)
guest381
« on: February 18, 2011, 08:17:39 PM »
After much hassle I have found the problem!!! There is a main earth wire in the loom which splits at the front of the loom to the main head light, indicators and main earth, after further inspection and stripping down of the loom itself it was found to be rotten through it's entire length. It is cripped at either end and is only about a foot long but this was the source of all my problems, it had continuity but I guess under load it caused an problem which kept on frying reg/recs. Now all is well. Check your loom under all the insulation tape!
nixt
Re: SRX 600 Reg/Rec keeps blowing????
« Reply #1 on: February 01, 2012, 09:51:15 AM »
hi, sorry for my poor french...hope you can understand
i'm having  a problem I can't identify, so hopefully some of you can help me.
anytime I start my bike, it goes up with rpm, than hesitates for a while, and then it goes down till it dies...
here what I mean (I'm not touching the throttle at all)
http://www.youtube.com/watch?v=ZJxvbPCzv6k
the bike has modified cammes (for high), lightened flywheel, aftermarket exhaust.
it used to have mounted a cr 33 keihin, but thinking that could have been the problem, I replaced it  with the original one...still the same problem.
I replaced the CDi, but nothing changes
sooooo...what may be the problem?
« Reply #2 on: February 01, 2012, 02:43:45 PM »
Hi Nixt...
It sounds like fuel starvation (or water in fuel) as the fuel mixture gets weaker the revs will increase.. then the engine will finally die.
check all pipes and the tap and make sure there are no air leaks in manifolds, empty fuel tank completely, clean filter in tank, fill with fresh fuel.
good luck
nixt
« Reply #3 on: February 01, 2012, 03:09:40 PM »
thanks Steve
I changed fuel just before shooting that video and the manifolds seems right...still, I'll have a try and will empty the tank again
any chance it may be related with the pickup?
thanks
Hi Nixt...
good luck
Frog
« Reply #4 on: February 01, 2012, 04:31:13 PM »
I too would suspect fuel - given the same prob with two carbs I would check inlet manifold.
I have also had a similar problem with a duff coil - although generally after the coil had warmed up rather than straight from cold.
Frog
« Reply #5 on: February 01, 2012, 07:57:32 PM »
Apart from the poor tickover does the bike run ok when riding ? Are you using the standard fuel tap, if so does it run better when the tap is set to the 'prime' position ?
Steve
