Author Topic: srx400 front sprocket  (Read 581 times)
guest668
« on: October 28, 2010, 07:28:21 PM »
have hit a snag in taking engine out cant undo the nut holding the front sprocket in place ..its a different set up to my 600 comprising of a tab washer over a 30mm nut...have bent tab washer back applied brake and put bike into gear but nut wont budge...it wouldnt be a reverse thread would it? anyone else had problems like this or have any tips have applied loads of penetrant spray to no affect...many thanks
Fuzz
Re: srx400 front sprocket
« Reply #1 on: October 28, 2010, 08:58:58 PM »
Easiest way...
Use an AIR gun !!!!
Used one on my XT500 & the clutch centre & crank nut on my XBR.....
guest668
« Reply #2 on: October 29, 2010, 06:23:40 AM »
unfortunately i dont have access to an ar gun..
« Reply #3 on: October 29, 2010, 10:13:50 AM »
An air gun is the way to go, take it to your local car garage and get them to undo it for you.
Steve
beeman
« Reply #4 on: October 29, 2010, 01:47:40 PM »
If you are replacing the sprocket make sure you get the right one as the splines are different for some 400's.
guest668
« Reply #5 on: October 30, 2010, 10:41:18 AM »
pushed bike down to local garage and they got it off in seconds with air gun...thanks for all your help
