Author Topic: smoking srx400  (Read 940 times)
guest668
smoking srx400
« on: September 02, 2010, 08:00:48 PM »
my trusty old srx400 ticks over fine but gives off white smoke when throttle blipped or under acceleration...any ideas anyone...performance is not affected runs fine otherwise....have recently changed oil.
Re: smoking srx400
« Reply #1 on: September 03, 2010, 08:09:05 PM »
coolant leaking into combustion chamber or exhaust tract? :D
Re: smoking srx400
« Reply #2 on: September 03, 2010, 08:20:03 PM »
sorry....i'll try and be a bit more adult about this,
sounds like oil in the system somewhere....is there too much oil?...so that the breather is recycling it into the airbox?
got oil in the petrol somehow?.......topped up with deisel?
not much help i know
guest668
Re: smoking srx400
« Reply #3 on: September 04, 2010, 10:46:21 AM »
hi steve thats what i was thinking but checked the oil and it seems to be at the right level at the upper end of the dip stick might give frop the level though and see if it helps.
tj63
Re: smoking srx400
« Reply #4 on: September 06, 2010, 12:19:46 PM »
It sounds like the same problem I had with mine when I overfilled it.  The oil has to be a measured amount - if there's too much it will "wet sump" on you.
Take some oil out, then get the engine warmed up.  Stand the bike upright with the engine running for half a minute then stop it and check the level on the dipstick (without it screwed in).  This will give the proper reading of how much is in there.
Trevor
Re: smoking srx400
« Reply #5 on: September 06, 2010, 12:33:06 PM »
As long as the non-return valve is working ok (it's on the inside of the r/h casing) then it shouldn't 'wetsump' but TJ is correct about the oil levels.....take the bike for a run, then let it stand for 10 mins, then, with the bike upright (not leaning on the sidestand) check the level...i always check the level after the dipstick has been screwed in (or at least make an allowance if you are dipping it without screwing it in/out)
guest668
Re: smoking srx400
« Reply #6 on: September 06, 2010, 09:59:44 PM »
i dropped some of the oil today but its still smoking think i will check spark plug see if it is oiled up ....and then do complete oil change if that proves negative....could it be valve problem though i thought that tended to give a blue smoke....or maybe petrol problem water in tank?
Re: smoking srx400
« Reply #7 on: September 07, 2010, 06:52:25 AM »
Is it the same when the bike has thoroughly warmed up, did it do it prior to the oil change?
guest668
Re: smoking srx400
« Reply #8 on: September 07, 2010, 05:42:27 PM »
yes it was warmed up and no it didnt
Re: smoking srx400
« Reply #9 on: September 07, 2010, 07:58:51 PM »
what oil have you used?
Re: smoking srx400
« Reply #10 on: September 07, 2010, 08:41:03 PM »
Is the choke stuck on ?
guest668
Re: smoking srx400
« Reply #11 on: September 08, 2010, 09:39:53 PM »
it was castrol semi synthetic motorcycle oil....and have checked choke and def not stuck on....though plunger nut snapped when i reinstalled it so am now in need of a new one aaaagh!!!!!!!
