Author Topic: looking to get a xbr  (Read 432 times)
dimplexone
« on: August 14, 2010, 12:38:48 PM »
Hi
i will be looking at a couple of xbrs this w/end . ;D ;D
What are the main problems to check for on these bikes  apart from age and normal ware .
also whats the difference in the h and the f models as listed on ebay .
Dimplexone
guest833
Re: looking to get a xbr
« Reply #1 on: August 15, 2010, 11:58:41 AM »
Hi-
The back brake drum can go oval- just ride and touch on the back brake to check for roundness. Also the tappets/ cam tensioner can cause top end rattling. the electric starters can cause problems. The petrol tanks can leak on the front bottom seam- check for filler. The rear seat covers are getting like rocking horse *******e. Original twin exhausts again difficult to come across. The bike may have an aftermarket single motad or micron now. You can get stainless single side for about £325  Just check over the bike for usual stuff- easy starting from cold, suspension, electrics, frame condition etc
The f is an earlier model and the h a later model. The h will have the front indicators drilled through the headlight mount and a lump in the starter cover as opposed to flat on the earlier models. The h may be in silver as that was a later colour
If you get one and need any spares give us a shout
Cheers- John 07990 810934
