Author Topic: Quick CB250RS question...  (Read 501 times)
Danny Boy
« on: August 09, 2010, 07:23:01 PM »
Wonder if I could just pick the Club's collective brain. How hot is a 250RS supposed to get? A quick 20 minute blast and mine's cooking. Timing looks OK, tweaked the carb to run a bit richer, but still the same. Am I looking for a problem that ain't there? This is my first thumper and I don't know how much heat that big lump of piston generates.
Cheers, all.
Re: Quick CB250RS question...
« Reply #1 on: August 09, 2010, 08:00:04 PM »
Danny Boy
With the air temperature fairly high at the moment it won't take long for the hard revving little motor to get itself excited. Do you know that it is running hot (by actual measurement) or do you just feel that it is? For an air cooled twenty year old bike I wouldn't say that mine runs very hot, but if you are used to more modern stuff its cooling system, relatively low oil capacity and lack of oil cooler might seem a bit primitive. If it is running very hot the exhaust down pipes should be an indicator - are they blue/silver or glowing red? If the former I would think your concerns are from the high ambient air temperature (low worries within reason), if the latter it could be a serious timing/fueling problem (big worries pretty soon), if its somewhere in the middle running it rich will help in the short term but it will need sorting to avoid, on going, long term problems. Have you checked the valve clearances?
Probably not much help in exact terms but the CB250RS is a very tolerant little big that will, as I try to prove, put up with a lot of abuse and minimal servicing!
Danny Boy
« Reply #2 on: August 09, 2010, 11:23:03 PM »
Maybe I am just looking too hard at this one. Cheers for the calming words.
« Reply #3 on: August 25, 2010, 09:55:00 PM »
My XT250 header used to glow at night - these aircooled things get pretty hot at times
