Author Topic: fornt sprocket  (Read 482 times)
guest668
fornt sprocket
« on: July 29, 2010, 06:51:06 AM »
hi another question which is the easiest way to remove the front sprocket on an engine...no chain fitted yet so old sprocket is free moving....may thanks
Re: fornt sprocket
« Reply #1 on: July 29, 2010, 04:00:57 PM »
Put it in gear, use a good quality socket and if it won't budge then try an impact driver.
guest40
Re: fornt sprocket
« Reply #2 on: August 10, 2010, 09:18:37 AM »
Don't forget to check if there is a tab washer locking the sprocket nut on.
guest668
Re: fornt sprocket
« Reply #3 on: August 10, 2010, 09:51:00 AM »
good point wasnt a locking tab on thesprocket should there be on an 85 srx600?
Re: fornt sprocket
« Reply #4 on: August 11, 2010, 10:22:00 PM »
There should be a locking tab if you have a plain shaft or a splined lock washer if you have a splined shaft
Let me know which one you have and I will send you the part number
Ian :)
