Author Topic: XBR500 CARB replacement  (Read 1526 times)
paulp2655
« on: May 30, 2010, 07:35:22 AM »
Hello all
In the quest to cure the occasional cough on my XBR, i found that most of the screws were siezed in place, including the pilot screw. However in the process of removing the said pilot screw i have managed to damage the carb (yes I know what a fecking idiot).
So has anyone replaced a XBR carb with something else and if so what have you go for ? or is it best to try and track down a OE VE10A
I have emailed 4 Kiehin carb stockists in the UK for some help and NOT 1 has replied, so presumably they dont want my money.
Thanks in advance, all suggestions appreciated.
Re: XBR500 CARB replacement
« Reply #1 on: June 02, 2010, 04:27:18 PM »
I've got an XBR here that the previous owner converted to use the Bing carb off a BMW boxer (yes really!).
I am aiming to get it back onto the road in a month or so and I will report back then on its performance. The owner did the conversion because he commuted from Southend to London and wanted better fuel consumption.
  • Hero Member
« Reply #2 on: June 03, 2010, 09:28:34 PM »
The standard carb is usually a pretty well sorted and reliable unit and the only time folks tend to change them is when they are tuning the engine when a flat slide Mikuni is the way to go. Thats probably not what your looking for - it's feckin' expensive for starters.  I would try and source a replacement standard unit or try and get yours refurbished but it may not be cheap - they've been asking £100 for secondhand XBR carbs on Ebay recently! Apart from the screws what have you damaged?
It'll be interesting to see how that performs GC.
paulp2655
« Reply #3 on: June 05, 2010, 06:46:26 AM »
Thanks Steve
In a nutshell the pilot screw was seized, so I tried to remove it gently with a screw extractor, however i wasnt gentle enough and the alloy around it cracked when it came free. I might add that im so angry with myself.
Simmo has come to the rescue and has a carb to view, so I should be able to make a good one from two.
With regard to the flatslide mikuni, i may look at that if I can actually get a carb supplier to talk to me
  • Hero Member
« Reply #4 on: June 05, 2010, 11:22:40 AM »
Sounds like the way to go!
To be honest it's not really worth doing this on it's own. you would really need to also fit the 600cc piston - tuned cam/valves - exhaust etc to get any real benefit. If you really want to go this way put 'GB500 hop up' in Google search and there a good article from Cycle world tuning a GB500 with White Bros parts.
guest833
« Reply #5 on: June 05, 2010, 03:50:35 PM »
All it takes is a phonecall mate- 07990 810934
John
paulp2655
« Reply #6 on: June 05, 2010, 04:43:44 PM »
John
Sorry im a bit busy with domestic/family matters etc , im sure you understand. Just waiting for my Mother to go home.  ::)
« Reply #7 on: June 05, 2010, 05:25:12 PM »
I've run a 40mm Amal and a 40mm Dellorto on a tuned engine (various states of tune), I wouldn't recommend a flat slide for road use.
driller1962
« Reply #8 on: June 16, 2011, 11:41:47 AM »
hi
did you sort Xbr carb out, doing similar trick and was considering a mikuni vm36-4 but its the inlet manifold is the problem, what did you sort out
thanks ???
