Sunny day today so started on the first job on my list - removing and painting under the fuel tank.......as is often the case with me , should have left well alone
Looked a bit damp in a couple of places but no leaks or smells but a couple of prods with my screwdriver soon made three big holes - why dont I just leave things alone
So will have to make with some epoxy putty until I find a tank that is better than mine .
Air filter looks like it has been in there since the bike was built so more expense there and I have a rear tyre on order .
Was some good news today though I got my shiny indicators from Paul
Better get on - holes to fill !!
Update - ok holes filled so while that was drying had a look at the valve clearances ........one inlet a bit tight and I think the RH exhaust must have had twice the clearance it should - all reset to the Honda latest spec ( bit wider !) - fitting the last valve cover I find it wont tighten - was a bit loose on removal - threaded part had cracked away from the top hex............
, seems bike has more to fix on it than before I looked at it - not my fault - honest !
