Author Topic: XBR 500 Headlamp brackets / ears  (Read 507 times)
Sprunghub
« on: February 23, 2010, 03:27:34 PM »
A couple of queries on XBR headlamp ear's, if any one has a set off & to hand.
Are they made of alloy & thus polish'able? (if not, what is the metal ?).... what is the diameter of the 'bore' for the fork tube ?... & do they have some sort of integral rubber seal's for gripping the fork tube ?
cheers
guest833
Re: XBR 500 Headlamp brackets / ears
« Reply #1 on: February 23, 2010, 04:25:11 PM »
Hi-
I have a set. They are made of alloy hence polishable. They are 42mm diameter bore to the inside of the alloy. With the rubber insert they are 35 mm (approx)
A couple on Evil bay at present-
http://cgi.ebay.co.uk/Honda-XBR-500-Headlamp-Brackets_W0QQitemZ110497122495QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item19ba2448bf
http://cgi.ebay.co.uk/HONDA-XBR500-XBR-500-HEADLIGHT-FRONT-LIGHT-BRACKETS_W0QQitemZ200432307774QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item2eaab24e3e
The ones I have and these on ebay are the earlier type- at around 1987 (E reg) on they have a hole in half way down the side of each to house the later shorter indicators- this was an amendment to house them on these headlamp brackets to stop the indicators flopping about like "a lazy lob on"
I can sell my set for £10 plus postage. Let me know and i'll get a pic on
cheers
John
Sprunghub
« Reply #2 on: February 23, 2010, 04:56:32 PM »
Cheers John.....might be useful......
guest833
« Reply #3 on: February 23, 2010, 06:31:21 PM »
There you go- i have also dug out the metal stays that go down to the said floppy indicators-
They have the rubber inserts also. As you can see they will polish up fine and have no scratches
cheers-
[/img]
