Author Topic: srx600 not starting  (Read 1280 times)
Re: srx600 not starting
« Reply #15 on: October 23, 2009, 09:16:46 PM »
Sounds like the carbs are flooding.  I do not know the SRX but I think it has a vacuum tap on the tank - is it on prime (no valve) or is it on run and the diaphragm not sealing?  Is the float valve in the carb closing off - may be some dirt on it, ditto are the floats floating and closing off at the right point?  Is this with the choke on or off - if on, try turning it off - if off sounds like the float bowl overflowing.  Could try draining the float bowl - is their a drain screw and quickly trying to start the bike as the bowl refills - may give a clue before dismantling the carb.
Maybe I should leave this to someone who knows SRX's
