I am seeking sensible thoughts, before I disembowel the*********************************!
Went out tonight, having finally finished with Herrman the MuZ Tour, with the intent to sort Sally out for the road.
New chain and sprockets, new fork oil/dust seals/gaiters (initial reason for being off the road), change of oil afore laying up and a squirt of oil down the bore. Emptied the carb and some of that additive in the tank to keep it sweet.
Turned the motor over 4 times on the kickstart nice and slow, just to make sure it all turns with no knocks, clunks or bangs. Went to turn it over gentle again and the piston came up on compression stroke and stopped afore TDC with a 'dunk'!!!!!!!!!!
Have taken the spark plug out with same results when trying to turn the crank over.
Rocked the motor back of compression by engaging second and easing it back. No problem, no nasty scraping, but again refused to come over TDC with a 'dunk'!!!!!!!!!!
Tried turning over with the kickstart after taking out of gear and again crank turns until afore TDC, when there was another 'dunk'.
Bike was laid up after running with no problems and spun over 4 times after 6 month layup, so why the sudden 'dunk'
Seized ring in a land, exhaust valve come down and now stuck down with carbon/'gum'?
At present the carcass will be wheeled into a dark corner, afore having the motor removed, prior to a full strip down, from the top down.
Sensible thoughts please.
Bill.
