Hi all
Mumpth question but I am sure I have missed something and I dont want to take another bike apart for a "Doh!" moment...
Not getting a spark on the CG. After a bit of fiddling I thought that the points were not opening - the Black and White wire from the points to the low tension side of the coil were showing continuity all the time.
Fiddling a bit more - putting an ohms meter across the points and seperating the electrodes produced no change - should have gone to infinity?
Have taken points out and disconnected the junction carrying the wires from the generator etc to the rest of the loom to see where the possible fault is. Neither end of the wire is touching the frame etc at the end yet I get continuity to earth - I have a short between the wire and the frame / engine somewhere dont I. Should be just a bit of wire running from inside a casing through the loom to the junction, there is no other reason for the reading I get - or have I missed a real simple one here?
