Author Topic: Engine width question...  (Read 433 times)
« on: June 23, 2009, 11:22:39 PM »
Quick question... anyone able to suggest engines (1 cyl 4 strokes  ;) ) which might fit into an NSR125 chassis?
It is a perimeter frame so as long as the head will fit between the rails most other things can be worked around, anyone got engines lying around they could wave a ruler across?
Cheers in advance(!)
Smudge  :)
edited to add, electric start is good as it's aimed at swmbo who doesn't do kickstarting... ;)
Re: Engine width question...
« Reply #1 on: June 24, 2009, 08:29:04 AM »
I can measure up a Rotax 500 - single cam.  Mine is not lekky start but they are available, however the drive is on the right and the kick start is co-axial with the gear change so a couple of interesting tweeks needed.
