Author Topic: XBR footpeg mounting  (Read 635 times)
guest288
« on: April 18, 2009, 10:18:45 PM »
Hi All
I'm starting to get the XBR together, but one of the threads has stripped on the footrest arm- there is another bolt holding it, and I can get the bolt done up relatively tight before it then loses it's threading- would a drop of threadlock do the trick?
Re: XBR footpeg mounting
« Reply #1 on: April 19, 2009, 08:22:26 AM »
Do  you mean the threaded holes on the frame? If so then you can fit a longer bolt and use a nut on the back of the lug to tighten it all up.
guest288
« Reply #2 on: April 19, 2009, 09:27:36 AM »
Yes, thats the one- I have stainless allens in there, thought it looked a bit odd with the nut on the back- may have to do that on the other side too!  ;)
« Reply #3 on: April 19, 2009, 09:29:54 AM »
Given the age of XBR frames now, it's odds on you will HAVE to do it on both sides soon enough. The lug is a funny construction, it appears to be a solid piece of metal but it's actually more like a nut encased in a metal pressing.
Can you pass my anorak please?  ::)
« Reply #4 on: April 19, 2009, 07:27:38 PM »
Pass you anorak - I would not be able to eat it in the first place.
Another useful commentâ„¢
