Author Topic: Pipe from sump  (Read 547 times)
Majik
Pipe from sump
« on: March 16, 2009, 09:54:08 PM »
I whipped the tank off the new Goose to give her the once over, and on replacement, I've noticed a rubber pipe, which extends up from the sump then between the frame and stops just under the front of the petrol tank. Normally I would assume this was some kind of breather, but aside from feeling air pressure througfh it when she's running, the pipe has a clip at the top, indicating it should really be on a nipple somewhere. I've looked and looked, but can't see anywhere obvious - anyone any genius ideas? I'm paranoid as hell now. Especially since she rode home fine, but on a ride out this evening, I lost the mirror glass and the petrol pipe popped off :(
Re: Pipe from sump
« Reply #1 on: March 16, 2009, 11:25:02 PM »
"They all do that Sir"
No idea on the pipe though - does it go to the airbox and been missrouted in the past?
Re: Pipe from sump
« Reply #2 on: March 17, 2009, 12:55:37 AM »
Aye Majik,
Download this, I believe the motor is the same or very similar! Checked for virus' and none found by AVG.
http://rs378.rapidshare.com/files/126244433/Suzuki_DR350-S-SE_Manual__PDF_.zip
Would appear that your hose is a breather.
I hope this helps.
Regards, Bill.
