Author Topic: engine replacement  (Read 1024 times)
guest668
engine replacement
« on: February 22, 2009, 01:01:27 PM »
am wnating to put 600 engine into my srx400 frame does anyone now if this is a straight swap over or do i need to replace carbs (or rejet them) electrics or anything else....many thnaks for any help
Re: engine replacement
« Reply #1 on: February 22, 2009, 01:31:21 PM »
Assumming early twinshock. Then its a relatively straight swap, the engine will bolt straight in and exhaust mate up.
You would probabaly be better off getting 600 carbs rather than trying to rejet.
A 600 CDI would help, the UK and import SRX's have slightly different electrics so you will need a CDI of a 1JK import (the UK 1XL CDI can be made to work but its fiddly.
If its a later SRX400 twinshock with round three spoke wheels then the  gearbox sprocket has a different offset to the 600
guest668
« Reply #2 on: February 23, 2009, 04:44:06 PM »
mine is an 86/87 srx i think ...it has three spokes but is a kickstart model... does that mean the engine wouldnt fit right ..due to the diffwerence in the sprocket position or is there a way round it..many thnaks for all your help
« Reply #3 on: February 23, 2009, 05:36:23 PM »
PM me the chassis number and Ill check the parts list
