Author Topic: SRX decompressor  (Read 1571 times)
SRX decompressor
« on: October 11, 2006, 10:05:52 AM »
Sorry guys, these SRX top end posts are getting really boring (for you, not me!)
Anyone got an idea of how to reove the decompresser from the rocker box cover.  I can't quite see whats holding it in...
In the end I may just lockwire it, (very securely this time!!!!), rather than remove it & glue in a penny as I'd previously thought.
...all that extra weight tho.....!!
Re: SRX decompressor
« Reply #1 on: October 11, 2006, 11:27:55 AM »
If I had to guess, going by the shouder machined into the decompressor shaft I would say bolt 31 is responsible
« Reply #2 on: October 11, 2006, 12:02:24 PM »
Thank you kind sire!
I've just realised that the "manual" I got with the racer is less than complete!
Cheers Steve, catch you soon
J Hop
« Reply #3 on: October 11, 2006, 08:33:32 PM »
Here is a link to the engine section of the workshop manual that I was kindly given :- http://www.tar.hu/srx/anyagok/SRX_03A.pdf
« Reply #4 on: October 12, 2006, 08:30:32 AM »
cheers!
J Hop
« Reply #5 on: October 12, 2006, 06:38:04 PM »
If you wanted to you could replace the decompressor lever with a short piece of round bar of the same diameter. Leave the seal in place and get a groove the same size machined into the bar (or you could even file a slot in the bar with a round file) for the retaining bolt.
Or you could just saw up the standard lever and use that.
« Reply #6 on: October 13, 2006, 09:55:23 AM »
Good idea!  Food for thought.  May be easier in the long run.  Plus it wont fall out, like a penny, or worse, fall IN!!!  Now we just don't need that!!!
« Reply #7 on: October 20, 2006, 06:50:33 AM »
a piece of aluminium bar, of course !
