Hi Steve,
Thanx 4ur quick respose.
first of all some tech. correction..
1. the part removed out of the fork is, as you said "mudguard mounting bracket", which i'll b fixing it back after some grinding and chopping the both sides of the mudguard
2. reason to go for a fat tyre : I have
no other choice, this is the only 18" STREET tyre available in Kuwait, bear in mind that this s the
ONLY sole surviving 'SRX' in Q8 (according to the Yam dealer in Q8).
To get the latest chassis: i've only option in frond of me is
ebay.UK..where i used to order..
i had a problem with my chock cable-end. Replaced with yam R6 parts tapped with new thread on the carb. Also i'm using a Yam Raptor 660 chain and spocket, it's a bit heavier than sstock SRX. and swing-arm extended to 2 inch. stock exhoust replaced (cat bypassed) with a aluminum canister from Raptor. it sonuds really good.
i'll post the pics from home.
taken before fitting the pipes. note the extended swing-arm
cheers..
