Author Topic: Supermono 2008  (Read 1515 times)
OMEGAMAN
Supermono 2008
« on: February 20, 2008, 03:16:45 AM »
Really must get out & start building that tzr/srx mono for the coming season (6 weeks?), as well as building my son's srx400 track bike, as well as helping my mate & co-rider Simon, prepare his Rotax, as well as etc. etc. etc........
Have just picked up a good srx620 motor from Ashley Norrington so should have no excuses on that front? Just got to put the whole package together!
See photo's!!!!!!!!!!
OMEGAMAN
Re: Supermono 2008
« Reply #1 on: March 03, 2008, 06:11:41 PM »
Update.....
We now have a rolling chassis!!!!!!!!!!!!!!!
Frame--TZR250 Alloy (deltabox) modified to take SRX engine
Swingarm--TZR250
Yolkes--TZR250
Forks--TZR250 (but they do seem a bit shorter by about 4cm?) with progressive springs & re-worked valves etc. by Maxton. Also have been altered by Maxton to have quick release caliper (endurance style?)
Rear mono shock--A hagon (almost new(100 miles only) shock)
Rear brake--Std. TZR 2 piston item
Front brakes--Single std. TZR 4 piston caliper gripping a single large dia. TZR disc
Braded lines on both
Wheels-- are from a FZR400 (17x3.5 front & 17x4.5 rear) so easier to find tyres
Tyres-- to start with, I have a pair of Dunlop KR364's (that came with the bike, so they may be a bit old?, but we'll see how they go!
Will update as work progresses (hopefully quickly???)
Re: Supermono 2008
« Reply #2 on: March 03, 2008, 06:46:36 PM »
Re: Supermono 2008
« Reply #3 on: March 08, 2008, 09:37:39 AM »
Well that looks so much easier than trying to get a Rotax lump in one.
What have you done about the cradle - made one up or ignoring it?
Does the carb poke out into the bottom of the petrol tank?
OMEGAMAN
Re: Supermono 2008
« Reply #4 on: March 08, 2008, 04:13:11 PM »
My co-pilot, Simon, has a rotax in his tzr (reverse cyl) frame. Looks like a good fit!. Will post some photos of that soon!
I have a cradle? that fits on the front (not all way round), as you'll see in a later photo!
The tank has already been adapted to suit (by a previous owner!), so hopefully, no problems with the enourmously long carbs (Amals).
Again, will post photos as work progresses.
OMEGAMAN
Re: Supermono 2008
« Reply #5 on: March 22, 2008, 01:41:53 PM »
Have now got engine fitted (decided to go with the XT640 at last minute) (ignore the 95x84 as it's 98.5x84 - I think?)
Header pipes fitted
Carbs (amals) fitted
Oil lines & tank fitted (have decided to run without cooler?)
Electrics all fitted (we'll see?, fitted by a blind man in the dark & with frozen fingers!)
Should be some photos on site soon?
Must get out there now & get it finished so I can have a practice before Snett.
Re: Supermono 2008
« Reply #7 on: April 01, 2008, 06:24:23 PM »
hey...thats the dead spit of my track bike....bloody good chassis, and so light, not sure what the all up weight of mine is, but its like moving a 125  round in the garage....should go like stink...good luck
OMEGAMAN
Re: Supermono 2008
« Reply #8 on: April 05, 2008, 01:22:51 AM »
 :D   Update !
Nearly there -  Home made exhaust system fitted, everything in place (I think?), we've just put some petrol pipes on with double filter (as there's a lot of rust in the bottom of the cleaned out tank, seems petrol tight though?), quick spray paint of the tank (outside in the wind). In fact, almost together now except for the fairing etc.
Put some fuel & oil in, quick visual check & outside to the waiting rollers. Put into second gear, pull backwards until TDC & set on rollers. Young John in his rover starts up & sets rollers in motion, let the back wheel of the racebike get up to speed, put weight on the seat & dump clutch quickly but smoothly-------------BANG BANG BANG, she starts up first time & sounds good (LOUD!), find neutral, & let warm up for a min., checking for leaks (NONE), took it round the square to make sure brakes clutch etc. work ok, upset a few more neighbors?
Check it out ----    http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=31636666
Re: Supermono 2008
« Reply #9 on: April 05, 2008, 08:40:39 PM »
Tut tut!
Riding on the public road without gloves, what an example to set  :o (wags finger sternly)
Get to the naughty corner!
OMEGAMAN
Re: Supermono 2008
« Reply #10 on: April 06, 2008, 12:11:34 PM »
Which one?        I've got about 16 to choose from........ ::)
beeman
Re: Supermono 2008
« Reply #11 on: April 11, 2008, 09:07:58 PM »
Good top see it on the road, sorry that should be going.
Keep meaning to drop by but always too knackered after work.
beeman
