Author Topic: Gasket sets  (Read 808 times)
martyn
Gasket sets
« on: September 21, 2006, 07:22:12 PM »
I'm sure this has been answered before but I shall ask anyway. I'm about sort out 5th gear on my SRX and am thinking of using a pattern gasket set except for the head gasket were I intend to use genuine Yamaha. Any observations would be appreciated, particularly from people who have already done this job themselves. I think I will need genuine O rings as well as I am not sure that the pattern sets contain all the little bits.
Re: Gasket sets
« Reply #1 on: September 21, 2006, 07:54:53 PM »
Evening Martyn,
A pattern gasket between the right hand crankcase and the outer clutch cover casing blew with me, oil all over the back tyre!
When you strip the motor you will see that the width of the mating surfaces at ~10:00 o'clock, behind the kickstart, when viewed from the off side of the bike is very narrow. The difference in the quality of the 'pattern' and 'genuine' gasket material was very marked. The 'pattern' being made from thinner material, prone to deformation.
I check all case mating faces against a sheet of plate glass and try sliding a 2 thou feeler gauge between the surfaces, others may use a different thickness of guage. Also lightly paint a gasket cement onto the case surfaces, I use Honda's cement, before assembly. Torque to factory pattern and values.
Once motor has been re-assembled, run up and warmed through and cooled, check the torques where possible.
Cheers, Bill
Re: Gasket sets
« Reply #2 on: September 21, 2006, 08:00:53 PM »
Aye Martyn,
Try the 'Search' facility from the 'Menu Bar' on this page. Tick the boxes and away you go.
Works a treat and definitely essential when tracing some of the drivel, errrr sorry, astute prose tapped out for these pages!
Regards, Bill
martyn
Re: Gasket sets
« Reply #3 on: September 21, 2006, 09:35:57 PM »
Thanks for that Bill, perhaps I will lash out the extra and try all genuine gaskets in spite of the extra expense. I can't find a search facility on my menu bar. Am I missing something [Besides grey cells]?
Nathan
Re: Gasket sets
« Reply #4 on: September 22, 2006, 10:10:34 AM »
Ive half a cereal box on my side engine covers...
Hasnt caused a problem for 6months so far..
Re: Gasket sets
« Reply #5 on: September 22, 2006, 10:29:57 AM »
Dont they get soggy when it rains ?. Mine are polished, must more attractive ;-)
Nathan
Re: Gasket sets
« Reply #6 on: September 22, 2006, 12:20:52 PM »
Ah... Rule number eight: Beware the finicky.
