Hello all,
I’m on a train!! Amazing huh??!
Off to a wedding in Newcastle, and am gobbling up their free wireless tinterweb. Fabulous. Some technology I don’t hate (tho I did nearly throw a mates TomTom out the window the other night
). Still, electric start is still the “leg of satan” IMHO….
Anyway, I think all is good with our engine build. Or maybe not “good”, but progressing…!
The oilway problem is solved (I’ve got an external line, and some little slugs to block up the internal oilway), a set of RD springs coming, and Boyds coming down in February to see if it will actually go in the frame. Fingers crossed! He looks like he’s been busy with the chassis:
www.team-thumper.blogspot.comI was speaking to fellow supermono man dave bennet through the week. He reckons a flat top piston (as mine is) is not a great idea. I got this new wiseco piston (and barrel bored to suit) with the engine.
Apparently, he thinks it will suffer overburn in the middle of the piston.
This can be avoided by use of a domed hi comp piston. He also reckoned I’m giving away useful bhp by running this lower CR. I don’t doubt it.
According to Wiseco literature, this piston will give a CR of 10:1.
Whats the opinion on this? Remember that as a 690 it blew the top end off. I said this to dave, and he reckoned it could be prevented by using Ti barrel nuts and Ti head bolts (from slipstream). And they’re not as expensive as you’d think…
I’ll probably build it for the start of the season with the existing piston. If it holes, it holes, in that case I’ll replace it.
Maybe with an alternative
Any experience with hi comp pistons? The 620 srx had an arias, but I don’t think it was “lumpy”… Steve, Bill, do you know what is in your motors? And remember I still have the 102mm (690cc) hi comp wiseco to try towards the end of the season if I fancy, tho maybe that would just be a bit much…
Cheers,
