Author Topic: Tank sealant  (Read 557 times)
guest146
Tank sealant
« on: January 19, 2008, 04:06:17 PM »
I am renovating an old Francis Barnett and need to seal the fuel tank. Its Had a previous repair and has been filled over a weld. I was thinking of using this tank sealant.
Has anyone used it and can recommend a brand or advice on using
Cheers Ken
pigafetta
Re: Tank sealant
« Reply #1 on: January 19, 2008, 05:23:17 PM »
I used a kit from www.frost.co.uk recently on a CB900 tank. I went for that one because you get everything you need for £25 so I didn't have to go around pricing up petseal and etching stuff and whatnot. Results were favourable, it's a slag of a job though. Frosts are pretty good, they do loads of useful restoration stuff. Not terribly cheap but not hugely expensive.
Dave B
trophydave
  • Dave the rave
Re: Tank sealant
« Reply #2 on: January 19, 2008, 06:21:01 PM »
I did my old MZ 2 smoke tank with POR15,I got it from Frosts.If you use that make sure you mix it well-it looks like Hammerite-and keep moving the tank around to ensure coverage.It was still fine when I sold the bike a couple of years later.
guest146
Re: Tank sealant
« Reply #3 on: January 28, 2008, 07:42:56 PM »
Bought the kit thanks
Will use in a week or two
