converting comstar hubs to spoked rims isnt hard. ive owned a set of goldwing hubs that had been laced onto spoked rims for a sidecar outfit. basically, you dismantle the wheel and keep only the hub. then you get the size of rim you want, 17/18/19 inch, (my wing actually had a 15 on the back and a 16 on the front) when you have your rim, you will know how many spokes need to go to each side, you manufacure a disk from ally that bolts to the hub using the comstar mounting bolt holes, and into this disk you drill the holes at the calculated distance for the spokes to attatch to. from there its just a case of building it up. i'll try and find some pics of the wing wheel i had showing the detail. its quite a simple process. (if you are confident building spoked wheels that is!!!)
