Author Topic: yam advice please! -ignore if my threads are p'ssin you off!!-  (Read 3329 times)
Re: yam advice please! -ignore if my threads are p'ssin you off!!-
« Reply #30 on: November 29, 2007, 04:54:32 PM »
It's nice to know she does a turn Andy....can we all have a go with her next year?? :-)
« Reply #31 on: November 29, 2007, 10:47:37 PM »
Aye Andy,
Delighted to read the diplomacy is successful. Also that the cantankerous one turns smoothly with no clicks, clunks or grinding noises.
It's cowping it here at present.
« Reply #32 on: November 29, 2007, 11:14:07 PM »
Aye, thanks guys!
However, I've learned the hard way that Blu Tak is no good for checking clearences.  Its.... "tacky"... funny that    >:(
So, repeat with real plasticene.
Sorry guys, progress is painfully slow!
« Reply #33 on: November 30, 2007, 02:48:26 PM »
Modelling clay is another option, as it will go hard eventually making measurement easier. I thought I would be clever and sprayed the piston with WD40 before putting the plasticine in place. I ended up with a soggy mess.
« Last Edit: November 30, 2007, 07:52:42 PM by Steve H »
« Reply #34 on: November 30, 2007, 04:18:16 PM »
Exactly as I was going to do!  OK then, thanks for that, you've potentially saved me from a 3rd strip down!  I will however wipe the faces of the valves lightly with oil...
May try modelling clay, but fear it would shrink slightly as it dries??  Will let you know how I get on over the weekend.
« Last Edit: November 30, 2007, 07:52:55 PM by Steve H »
« Reply #35 on: December 01, 2007, 01:44:18 AM »
Modeling clay shrinks a lot on drying - is why I like soft solder - needs to be soft mind - as it squishes but can be mic'ed up - have never had probs with it marking the ally piston or head - guess you need to try some on a bit of ally first - see what scratches what.  Also if you are looking for - say a 0.3mm clearance - then use 0.5mm solder not 5mm solder - it only needs a couple of flats on it - does not need to be squashed over the whole of the piston.  3 tabs 120 degrees apart running from the crown to the edge, little thicker than the gap should be.  if it does not squash than you are some distance off ...
« Reply #36 on: December 02, 2007, 01:37:01 PM »
Hi all,
got some plasticine!
Info on the blog, thanks a lot for the help!!  We are on the way.  Just slowly!!
Time to get it out to the garage I reckon...  easier!
cheers for now thanks again for all the info, encouragement, etc
http://team-thumper.blogspot.com
