Author Topic: Fecking Batteries!!!  (Read 549 times)
« on: August 29, 2007, 11:34:59 AM »
Are we all in the same boat here??!!
The skorpion was out of service for a few weeks, so obviously the battery died.  I thik I charged it, but left it a couple of days.  So then I "jumped it" off the battery powering the garage (12v).  Very handy, can now do it without removing any parts from bike, but am considering putting am easy-access socket...!!!  (ok maybe not the last bit)
(Actually, I'd rather fit a kickstart!!)
I have been running with no lights to try to charge it.  Except 100 miles motorway trip, with headlights.  IT was fine, but next day, no starting.  I jumped it off the garage battery again, and it now generally starts as long as I don't use the lights.
So I think I need a new battery
While using the Skorp, and having a long holiday, the DR was out of use.  I got it back after the jols.  Battery's flat.  I charged it last night, and I'm sure its knackered, wouldn't pull charge at all at first, then 3A, 2A, 1A.  I will get the voltmeter on it this evening.
I fear its also knackered.
Both The DR and skorp have working alternators (lights work when running), and no obvious faults in wiing, reg-rect, etc.
So I should have 12v engine off, and about 13.5v engine running, right??
And the plates look to be discoloured and sedimented.  Knackered?!
And are singles just good at wrecking batteries??  I will try to insulate them nexty time (from vibes) as both just sit in little metal carriers.
Both batteries are good brands (Yuasa I think) and I bought new, about 18 months ago, and filled myself.
As the garage is solar now, I think I'll wire in some trickle charge jack plugs from the walls near where I park the bikes, and keep them on a "daytime trickle feed" for when they're laid up.  Plus they can be used to power my lights, radio etc!  :)
Can you offer advice to my queries?  I think I'll have to fork out anyway (although I am VERY tight, so maybe not quite yet!)   Catch you all later
ps.  Bill- needing bits??  I have CDI, and reg-rects I think.  Need????
Re: Fecking Batteries!!!
« Reply #1 on: August 29, 2007, 12:00:34 PM »
You are right about the battery voltages for checking (12/13.5). A lack of volts plus discoloured plates would have me heading out to buy a new one.  :'(
I am no fan of "trickle" or "smart" chargers though. Batteries need to work. Any charger can take a week to do a twelve hour job, or stop when it's had enough, but it takes something really clever to put a load on and take the power out (thus preventing the thing expecting high voltage to push any sort of current by marking the plates structure). I'd buy a new battery for starters and fit some QD means of removing it from the bike (also a security measure). If a new battery won't hold power for a few weeks I'd be thinking about just how much you need to do the job, what condition the earth is in, what leaks to ground you've got etc.
I too would agree every bike should have a kick start!
« Reply #2 on: August 29, 2007, 12:18:18 PM »
If you look at the battery people's splurge they suggest that you should replace the battery every year - now whilst I would not go that far, a MC battery driving a lekky boot has a hard life.  Yup I am a great lover of kick starters and cannot really see the need for lekky boots unless it is a pig to start or you have other reasons (aka Damo).
Lead acid batteries like to be cycled to keep them clean and running - heavy discharge and recharge etc.  I understand some of the battery managers do this.
Using the bike batteries to run radio / lights etc in the garage should help towards this.
Vibrations are not good for them - do not know if gel batteries are better in this respect - though they do not last as long (so I am told)
