Author Topic: TZRotax slow but sure  (Read 709 times)
« on: July 22, 2007, 07:18:23 PM »
Well I picked up the rear wheel from GC - sorry mate a balls up on the cash front means I owe you £5 - and have it fitted.  Was easy one I realised I had measured it with the sprocket carrier in place - panic that I had not - and also when I realised that the reason the sprocket carrier would not fit was because I was trying to fit it to the brake mounts... ummmmmm
Couple of spacers and a bored out RS125 spindle later it was in the fram and looking fine.  I think it is 0.7mm off centre - but I have decided that I will not worry too much until I am sure - think the ME took over and I was getting all worried about what may not be an issue.
Now (amongst 200 other jobs on it) need to get a rear disk so I can get the brake mounted in the right place. - Oh and see if the old tyre I have put on it will blow out and seat so I can roll it around a little (lot) easier.
Did not do owt to the CG cos she is outside and it was raining.
