Author Topic: srx headlight  (Read 658 times)
chippy
srx headlight
« on: May 14, 2007, 07:06:59 PM »
Hi
    On my srx bitsa the headlight unit has two screws at top and bottom, that the light unit pivots on,there is a screw on the nearside that adjusts  the left right aim.
 The unit seems loose ,should it have a spring for the aim screw to pull against?Or another screw on the offside ?
 I am new to japanese machinery so all help is appreciated.
bikeseamus
Re: srx headlight
« Reply #1 on: May 15, 2007, 03:31:50 AM »
Yes
         It should have a long spring on the outside of the adjusting screw. Any online parts blow up will show it, as well as the part number you will need.
chippy
Re: srx headlight
« Reply #2 on: May 15, 2007, 12:55:28 PM »
Thanks.Where do I find an online parts list or exploded view?
                       Cheers Chippy
Re: srx headlight
« Reply #3 on: May 15, 2007, 01:18:03 PM »
try SteveH's site   http://www.srx600.net/
chippy
Re: srx headlight
« Reply #4 on: May 15, 2007, 06:14:49 PM »
Thanks,I got the partno from there.Is there a similar site with parts lists etc for the szr as the lump is from a later szr?
Thanks again for the quick reply.
                                          Cheers Chippy
