Author Topic: Ethanol effect on fuel filters  (Read 742 times)
« on: June 09, 2021, 10:31:32 PM »
This is just a wee warning to anybody purchasing fuel filters for their machine.
I have been using the little square plastic fuel filters manufactured by 'MRC', as they fit neatly out of the way in the confined space on the SRX twin shock and Monoshock. I have also fitted them to the Duke and the Morini, the latter uses 'SuperUnleaded' because of it's 11.5:1 compression ratio from the use of the "Heron" cylinder head.
Both the white filter from the Duke and the blue filter (was green!) from the Morini, show deformation of the filter element, so that it is no longer effective and the resulting contamination of the fuel may also be affecting the running of the engine.
I attach a couple of images that demonstrate the problem.
« Last Edit: June 09, 2021, 10:37:30 PM by themoudie »
