That's a shame,
I very much doubt if an exhaust centre will be much help but you can't lose anything by asking. Getting the Micron off is very easy but be VERY careful undoing the clamp nuts. I have broken off those in the past and it can be very difficult to get the broken studs out. The last one I ended up TIG welding a new stud on. The last one I was struggling with, I carefully cut the nut down with a dremmel to avoid breaking the stud. I always use brass nuts to prevent problems later.
Once off, the reason for the break will decide what you need to do. If it was because of excess corrosion, you may be able to find someone who can weld in a new section although, again, an exhaust fitting place is unlikely to be able to help.
If corrosion is not too bad, and the fracture is clean, it should be quite easy to get it repaired but there would probably be a reason for it to break such as too much tension in the system which would need addressing.
If you are not sure of any of it, get back to us and someone will be able to help.
Cheers,
Richard.
