Author Topic: Wheel machining  (Read 1717 times)
Wheel machining
« on: May 07, 2007, 06:44:27 PM »
Can anyone recommend an engineering company who can machine the disc mounts on my rear wheel. After much measuring an faffing about I've realised that not only are all the disc mounts are different heights but they vary in height radially as well. As soon as the bolt is tightened it tilts the disc and warps it. Joy
beeman
Re: Wheel machining
« Reply #1 on: May 07, 2007, 07:40:14 PM »
Would another wheel be cheaper, as long as that isn't warped!
beeman
Re: Wheel machining
« Reply #2 on: May 07, 2007, 07:43:17 PM »
beeman
With standard wheels it would probabaly be the easiest options but its my spoked wheels. I might try and find another hub, but then would have to have it painted and then the rim moved across.
Re: Wheel machining
« Reply #3 on: May 07, 2007, 07:59:11 PM »
GC's buddy in Cardiff has my rear at the mo - machining the hub back - he may be able to do it for you - GC says he is good and reasonable price - I have not paid nor seen the work yet so I do no tknow
Re: Wheel machining
« Reply #4 on: May 07, 2007, 09:22:21 PM »
Brian North is his name and he is at Major Road,Canton.
And Yes he is very good.
I use him for shop work and my own stuff.
Does look like Benny Hill and likes Jam Doghnuts.
Re: Wheel machining
« Reply #5 on: May 07, 2007, 10:50:06 PM »
There we go - Benny Hill is turning my Aprilia 125 wheel in to jam doughnuts...
So long as it works - and I measured it right we should be OK
Re: Wheel machining
« Reply #6 on: May 08, 2007, 07:09:03 AM »
Cheers for that. I'll get the tyre of and get the wheel to him.
Re: Wheel machining
« Reply #7 on: May 08, 2007, 11:36:58 AM »
He's only there in the mornings and be prepared for a lengthy visit, he likes a chat.
He will need the wheel spindle and nut too.
Re: Wheel machining
« Reply #8 on: May 16, 2007, 12:12:22 PM »
Sorted ! Just hope it soves the problem.
Re: Wheel machining
« Reply #9 on: May 16, 2007, 11:04:39 PM »
Dont Forget The Doughnuts !
And let him know we recommended him to you.
He likes a good chat and does a good job for an Enthusiast as to a Numpty off the street.
Usually tells them to F@ck Oof !
Re: Wheel machining
« Reply #10 on: May 16, 2007, 11:27:56 PM »
Sounds like Terry Hobbs - God rest his little cotton socks.  If he did not say fook and bloody in the last six words you were not listening.  And Monty his No2 was so mild mannered and quietly spoken - even when the following happened.
Me "Two gudgeon pin circlips please"
Monty "What for?"
Me "To stop the gudgeon pin coming out of the piston"
Monty "Yup, but what engine?"
Re: Wheel machining
« Reply #11 on: May 17, 2007, 06:48:39 AM »
I mentioned your name, by his response he knew who I meant !.
Re: Wheel machining
« Reply #12 on: May 17, 2007, 04:21:05 PM »
I bet he did !   LOL
Was his language Flowery ?  And Payed me lots of compliments ?
Re: Wheel machining
« Reply #13 on: May 17, 2007, 04:54:50 PM »
Fairly
Nope !
