Author Topic: Ural headache for sale on eBay  (Read 954 times)
« on: October 05, 2020, 11:00:52 PM »
Thinking of steveC#222 for this one. They're at the end of their tether trying to fix it. Might be worth a very low offer? Anyway, the folks selling it being Yorkshiremen,  it's all explained in the the very frank description!😁
https://www.ebay.co.uk/itm/333738838780
« Last Edit: October 06, 2020, 09:42:41 AM by mthee »
Re: Ural headache for sale on eBay
« Reply #1 on: October 06, 2020, 09:52:59 AM »
Timing/points? (assuming they still have them). Official Ural timing method is set points, loosen screws to rotate timing housing, turn on ignition, hang 8mm spanner off on one end of the coil (magnetised) rotate points housing until spanner falls off - timing mark!!!  ;D
Carbs out of balance- not lifting evenly?  Unofficial syncronisation method - take off inlet pipes from carb to airfilter, put bike on main stand, sit on bike, stick big toes (minus socks) into carb mouths touching slides, open throttle slowly and adjust until both sides lift at the same time ! :o...works.
« Reply #2 on: October 06, 2020, 10:19:32 AM »
This is priceless and if it was anyone else telling me, I wouldn't believe them!🤯😂
Anyway, I think eBay must have introduced some form of polygraph test before sellers can list;
https://www.ebay.co.uk/itm/164403508169
« Reply #3 on: October 06, 2020, 11:38:39 AM »
Yes,,, this post should defo be moved to the humour section. Brilliant 🤣🤣
« Reply #4 on: October 06, 2020, 02:39:10 PM »
Cor blimey! If I had that sort of money burning a hole in my pocket, that would be the very bottom of my list. Ugh...
« Reply #5 on: October 06, 2020, 05:06:13 PM »
according to the writeup it has electronic ignition, i'm betting thats where the problem is .... obviously originally it was points & magnets etc .... so the electronic stuff must be aftermarket
« Reply #6 on: October 06, 2020, 10:24:30 PM »
Sounds a bit like a Ducati 450 MKII in my workshop!  >:(
Bill
« Reply #7 on: October 07, 2020, 02:55:31 PM »
oh you're such a show off Bill :-)
« Reply #8 on: October 07, 2020, 07:45:23 PM »
Aye Steve, nothing to show off, carbs and ignition still causing grief! Hence, my post. However, I have a new carb and will see if this can tempt the b*gger into running!  :o
« Reply #9 on: October 07, 2020, 08:09:32 PM »
Best of luck with the new carb ya show off... eerr I mean. Bill 😉
