Author Topic: MZ carburettor question  (Read 923 times)
Silverfox
« on: July 18, 2020, 05:03:33 PM »
MZ traveller carburettor question - i took the carb off my MZ a few months ago and i am now rebuilding the bike, but i cant remember where the hose from the left hand inlet manifold connects to, see pic below? Can anyone help?
Gareth
Re: MZ carburettor question
« Reply #1 on: July 18, 2020, 10:24:06 PM »
Aye Gareth,
If I remember correctly the vacuum spigot connects via a short hose length looped over the top to the vacuum spigot on the fuel tap. I attach a wee snap of the left-hand inlet tract on Sally (SRX600 twinshock) and the same set up is used on the monoshock, with the XT600E motor. I have taken an additional vacuum hose off to the Scott Oiler that is housed in the tool compartment next to the battery under the seat.
I hope this helps.
Silverfox
« Reply #2 on: July 19, 2020, 07:48:28 AM »
i dont have a  vacuum spigot on the fuel tap!
« Reply #3 on: July 19, 2020, 01:00:57 PM »
Aye Gareth,
OK. I have looked at the SZR660 manual and it would appear that it is the vacuum take-off for the fuel pump, as described on page 126, Section H14, of the manual that I sent you. I cannot remember whether the MZ Skorpion had a fuel pump or not, as I never dived into it's guts that far!
I would suggest that you just blank it off in that case with a rubber cap, if no vacuum fuel pump is fitted.
Hopefully, this solves your dilemma.
Silverfox
« Reply #4 on: July 19, 2020, 01:36:58 PM »
Thanks for that, tis most helpful.
