Still having problems with the DR. Symptoms are
- With a steady throttle its fine at any speed
- Open the throttle in 5th at anywhere between 50mph and 80mph and it will stumble cough and be reluctant to accelerate.
- Any other gear is fine, I can nail it from 20mph in second up to 90+ and it is fine.
- Bike is largely standard
- CV carbs have been replaced with a tidy secondhand set, and certainly helped.
- Only happens on my way home, never in the morning when cold.
- Particularly bad on one stretch of windy road which is 25 - 30 miles into my journey home.
- I tend to ride in top and roll the throttle on and off, which exacerbates the problem (and no I dont want to change the way I ride)
- Lowering the needles makes no difference.
My feeling is its one of two things.
- The slides in the CV carbs are rising too quickly making the mixture too rich.
- The slides are sticking.
Gut feeling is the later, but how do I fix it. They are plastic slides in an aliminium housing, and dont appear to be worn, is there anything I can use to lube them that wont just wash off.
Steve
